2000 Dodge Caravan NO turn signals or hazard
HUNGIRL
2000 Doge Caravan, New flasher, and new bulbs. Combo switch works ( hooked up to another dodge and it worked.) All fuses read juice under hood and under dash. All tail lights and brake lights work, parking lights work. However we did find that the connector that plugs into the combonation switch by going over with a 12V tester that one wire that is suppose to be live at all times was not. Also just found out from previous owner that I should have daytime running light (park lights) and I dont. Can anyone figure this out?
Aug 28, 2006 at 5:01 AM
CHRYSLER300GUY
  • 18 POSTS
Need to replace wiring. Causing shorts and can be a fire hazzard.
Sep 9, 2006 at 9:59 AM
BUBBA_KOSKI
  • 129 POSTS
check your circuit boards, in chrysler owned vehicles they can be a problem
Sep 28, 2006 at 3:05 PM
