2000 Dodge Caravan my tailgate door wont unlock due to actu
2000 DODGE CARAVAN
133,000 MILES • 6 CYL • 2WD • AUTOMATIC
LOHMAN3
can u tell me how to unlock the rear tailgate when the actuator has failed - my key wont unlock the tailgate either because it wont turn far enough to unlock the tailgate. how do i repair in this situation.
Feb 15, 2010 at 8:21 AM
CH112063
  • 1,320 POSTS
If you cannot turn the key far enough you'll have to crawl inside and remove the plastic trim to expose the lock mechanism,a key cylinder and a latch mechanism. and a long pin connects them. The pin connects the cylinder to the latch, the latch in some cases can be adjusted by loosening a hex screw on it and moving the pin slide. Right where the pin connects to the latch. If not you may have to replace it, you'll see how it just unbolts. You may use the old key cylinder, just the latch assembly may need replacement.
Feb 15, 2010 at 1:47 PM
