Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Caravan
Engine
Mount
Replace/Remove
2000 Dodge Caravan motor mounts
2000 DODGE CARAVAN
119,000 MILES • 6 CYL • FWD • AUTOMATIC
MARKSGARAGE
MEMBER
1 POST
changed front motor mount okay, how do you change front right mount anchor 2844 or 2959? having trouble with bolts
Feb 12, 2008 at 3:40 PM
2CARPRO JACK
Experienced Mechanic
You mean the one up against the firewall D/S? If I remember correctly, you can get to them from the top if you remove the airbox
Feb 12, 2008 at 11:42 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
