2000 Dodge Caravan jumping when accelerating and cutting of
JENNAC126
Engine Performance problem
2000 Dodge Caravan 6 cyl All Wheel Drive Automatic 3.0 miles
i have a dodge carvan and when you accelerate it tends to do some jumping and acting like it wants to cut off when your driving, however when you stop at stoplights or even if i m backing up and go to switch gears it shuts off, but you can put it in neutral and recrank it with no problem. i have checked the machine and it first said map sensor high voltage and the next time it read 1st gear ratio incorrect, everytime it pops a different code. i have replaced the map sensor, a new fuel pump, fuel filter, (about 1 year ago). i dunno whats wrong. any ideads?
Feb 21, 2010 at 7:37 AM
BMRFIXIT
  • 19,053 POSTS
Reset codes and drive till problem occur
Check for codes
What do you have for codes?
Feb 21, 2010 at 11:10 AM
