2000 Dodge Caravan IT WONT START
108,893 MILES • 6 CYL • FWD • AUTOMATIC
DASALLA
I TURN THE KEY, IT WINDS BUT NOT START .. SOMEONE TLD ME IT MIGHT B THE RELAY OR ELECTRICAL.. IS IT THAT?
May 10, 2010 at 3:48 PM
  • 75,988 POSTS
To determine if its fuel or spark problem do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
May 10, 2010 at 4:02 PM
