2000 Dodge Caravan install key switch
92,055 MILES • 6 CYL • 2WD • AUTOMATIC
JANNETTE1
I installed switch van cranks, cannot take out of park
Nov 8, 2009 at 8:25 PM
BMRFIXIT
  • 19,053 POSTS
The shift interlock system is mechanically or electronically operated, depending on model application.
System may be operated by cable connected between ignition switch and shifter, or by a solenoid mounted on upper steering column.
With ignition switch in OFF or ACC position, the gearshift lever is locked in Park. With ignition switch in UNLOCK or ON/RUN positions, the gearshift lever is unlocked and allows gearshift lever movement to any position.
The shift interlock system also prevents the ignition switch from being returned to OFF or ACC position unless gearshift lever is returned to Park.
Nov 8, 2009 at 10:11 PM
