2000 Dodge Caravan Hot air vs Cold air
155,000 MILES • 6 CYL • 2WD • AUTOMATIC
ABCDEDAD8
My ac unit is blowing extremely hot air from the drivers side vents and cold air from the passenger side and rear vents. How is this possible and what can I do to fix it?
Thanks for the input.
Aug 6, 2010 at 5:50 AM
  • 110,248 POSTS
Do you have dual climate control?
Aug 6, 2010 at 4:27 PM
ABCDEDAD8
Yes I do. But it blows out extremely hot air on the drivers side when I have the AC set for both.
Aug 9, 2010 at 11:03 AM
  • 110,248 POSTS
On your vehicle, there are two blend air doors. What they do is determine if you get heat or AC. They are located near the heater core. My guess is that one is working, and the other is stuck in the heat position.
Aug 10, 2010 at 3:45 PM
ABCDEDAD8
How should I proceed to repair this condition? Is this something I can do easily myself or shoud I seek ouut a professional?
Aug 11, 2010 at 5:29 AM
  • 110,248 POSTS
Well, if you have good mechanical ability, you may want to try it yourself. I have worked on cars for nearly 30 years. If I could pay someone to do it for me, I would. Part of the dash needs taken apart and removed.
Aug 11, 2010 at 3:36 PM
ABCDEDAD8
Where exactly are these doors located?
Aug 12, 2010 at 9:48 AM
  • 110,248 POSTS
Near the heater core.
Aug 12, 2010 at 4:44 PM
