2000 Dodge Caravan Front CV Joint Removal
111,000 MILES • 6 CYL • FWD • AUTOMATIC
DREWMAN1229
  • 6 POSTS
I have both sides loose on drivers side and i'm trying to remove trans. I have a manual. I followed to a tee. I am having no luck. Please help.
Oct 29, 2008 at 5:08 PM
BMRFIXIT
  • 19,053 POSTS
Can you elaborate I'm not clear on what is the question is it that the tranny stuck and can not remove or the CV axle stuck on the passenger side tranny side ? and if so it should slide out use a large screw driver to help it out let me know need manual CHECK IT @ https://www.2carpros.com/kpages/auto_repair_manuals.htm
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic_45.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_22.jpg
Oct 29, 2008 at 11:09 PM
