Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Caravan
Exterior Light
Headlight
2000 Dodge Caravan Foggy head lamps
2000 DODGE CARAVAN
110,000 MILES • 4 CYL • FWD • AUTOMATIC
DHORTON
MEMBER
head light covers are foggy and causing poor visibility . Unable to clean covers off to correct problem. Is there a solution to this problem
Jan 16, 2010 at 7:43 AM
CARADIODOC
Experienced Mechanic
If you can see moisture inside, and there is no vent tube on top, you can drill a small hole in the bottom of the housing.
If the lenses are yellowed, some people claim you can polish them to restore the clarity.
caradiodoc
Jan 17, 2010 at 9:03 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
