Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Caravan
Engine
Flywheel
Replace/Remove
2000 Dodge Caravan flywheel
2000 DODGE CARAVAN
141,965 MILES • 6 CYL • 2WD • AUTOMATIC
WARIOR
MEMBER
1 POST
How to install a flywheel
Aug 31, 2010 at 9:01 AM
Experienced Mechanic
The transmission and torque converter need removed. Once they are out, then you will have access to the bolts holding the flywheel to the crankshaft.
Sep 1, 2010 at 12:12 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
