2000 Dodge Caravan Engine won't start
126,000 MILES • 6 CYL • 2WD • AUTOMATIC
MARJASO
The vehilcle was running fine. Driving down the road and vehicle made slight popping sound as the engine died. The engine will not start and makes a popping sound while cranking. Engine getting fuel & fire, camshaft sensor, crankshaft sensor & timing chain check out OK. Think it is engine control computer. What tests do you recommend to verify?
Aug 26, 2010 at 12:17 PM
  • 75,988 POSTS
Start by checking the fuel pressure if its within specs
Oct 23, 2019 at 7:47 AM
  • 75,988 POSTS
Sound like no spark,check the ignition system.
