Engine started and fine idle for about five minuntes to warm engine. Then put column gear shift lever into "R" but the gear position box around the "P" did not move to the "R" position. This PRNDL on the dash is electronic. The vehicle did back-up, but stalled and the engine died after about two feet. I re-started the engine and it stalled with-in 2-3 seconds. I did this about four more times and the engine died each time. Then the engine would not start and hasn't started in two days. I noticed during the re-start that the odometer and PRNDL did not re-light on the instirment panel. They still won't come on when the ignition switch is turned on. HELP!
Mar 5, 2009 at 7:24 AM
