2000 Dodge Caravan engine light came one
QUTKDZ
2000 Dodge Caravan Automatic 89825 miles
okay, as I search for what the codes are suppose to mean I see that the troubles I have been experiencing with my van are the same as many others. Anyway, I did the trip/reset with the key on and ran a check and it gave me the #'s 20 55 75 and I think 8 but I cannot find what they mean. help
Jan 4, 2010 at 11:28 AM
CH112063
  • 1,320 POSTS
Who gave you these codes, there is a sentence, with these numbers that tells you exact information, the OBD connector has one set, for emissions related faults, the Chrysler codes are more exact,
either one should start with a P and then have 3 or 4 numbers, like 1775 or 0753, see if you can write down exactly what those numbers are, they are very important, what problems are you having?
take it slow, use a scanner, write them down then post a question, if you plan on fixing any newer car you will need this type of information and tools, all are available pretty cheap now, check the store, ok?
Jan 4, 2010 at 1:09 PM
