2000 Dodge Caravan engine cuts out
125,000 MILES • 6 CYL • FWD • AUTOMATIC
BREVARD49
Some days I have to jump start the van. Others it starts fine but the engine will cut out for no appart reason. I can get it to start again by either turning it back on or jump starting it. I have had the battery check twice and it seems to be ok.
Dec 30, 2009 at 11:11 AM
CH112063
  • 1,320 POSTS
To test a battery, a load test checks it internally. However if you have too much cable resistance it will cause all kinds of restart and charging system problems, Your engine needs a full 12.6 volts minimum for the sensors that run the signals for the computer and alternator to operate properly. I would try this, try a voltmeter on the battery, if the voltage when cranking it and disabling the coil(so it won't start) drops below 9.6 volts it is bad battery, if it hold above this and the engine will not crank, its a starter or cable problem,one or two battery cables may be corroded, and it may not be charging because of this.Or the terminals are corroded. Causing all this to happen.. hope this helps. Look inside each cable, if you see any green, replace them then test the alternator before testing the engine computer for fault codes. Use a razor, be careful.
Dec 30, 2009 at 12:08 PM
