2000 Dodge Caravan Electric side doors
65,000 MILES • 6 CYL • FWD • AUTOMATIC
DOO600
My electric side doors have stopped working when I try and use the switches inside by the door. The switch on the driver console still functions normally. No fuses are bad. One inside switch would most likely be a bad switch but both swithes not working. Any idea where to start to find this problem?
Feb 21, 2008 at 11:59 AM
BMRFIXIT
  • 19,053 POSTS
[quote:4c83e87b8d="doo600"]Electrical problem
2000 Dodge Caravan 6 cyl Front Wheel Drive Automatic 65000 miles
My electric side doors have stopped working when I try and use the switches inside by the door. The switch on the driver console still functions normally. No fuses are bad. One inside switch would most likely be a bad switch but both swithes not working. Any idea where to start to find this problem?[/quote:4c83e87b8d]
1: motor no good
2: It may be need to be flashed check with the dealer
Feb 21, 2008 at 12:17 PM
DOO600
motor has to be good, it works fine when you use the console switch.
Feb 21, 2008 at 12:34 PM
BMRFIXIT
  • 19,053 POSTS
[quote:e067f5645c="doo600"]motor has to be good, it works fine when you use the console switch.[/quote:e067f5645c]
i must mised that
on both doors!
they stopped working
do you have an excess to a scanner
to check the BCM data
Feb 21, 2008 at 12:40 PM
DOO600
[quote:c5c38353a5="BMRFIXIT"][quote:c5c38353a5="doo600"]motor has to be good, it works fine when you use the console switch.[/quote:c5c38353a5]
i must mised that
on both doors!
to check the BCM data[/quote:c5c38353a5]
You mean and OBD2 scanner? I have access to one of those but there are no indications that it is throwing a code.
Feb 21, 2008 at 1:06 PM
BMRFIXIT
  • 19,053 POSTS
its not PCM codes we re looking for.
its BCM (body control module )
we are trying to access
does it do that
Feb 21, 2008 at 1:29 PM
