2000 Dodge Caravan ECM module
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
CAITLINGRIEVE
How much would it cost to replace an ecm module for a 2000 Dodge Caravan? I checked online and a rebuilt one is about 260$, is the labour going to cost a lot?
Thanks
Aug 31, 2009 at 3:03 PM
MFOUDY
I have a 2001 Caravan Sport that's stuck in limp mode. Because of faulty information, I took out the ECM instead of the TCM and it was very easy. Mine is behind the driver's side headlight housing, between the battery and headlight housing. You disconnect the battery, unscrew two bolts on the top of the unit, then you have to take the headlight housing out to get to the bottom bolt (the bottom one seems to take FOREVER to get out). Then pull the two side connections off of the unit and you've got it. Install the new/reman. one in reverse order. I purchased my TCM from a remanufacture site that does both ECM's and TCM's. They reprogram to your make/model/VIN# and mileage. You send the old one back in a pre-paid box. There are several out there, but the one I used was: Auto Computer Exchange. Good luck!
Sep 3, 2009 at 4:51 AM
