2000 Dodge Caravan Control Module is leaking
308,000 MILES • 6 CYL • FWD • AUTOMATIC
PAPET
  • 105 POSTS
Dear Bob and Ken,
I just went for a transmission and filter change because there was a leak around the gasket. So the mechanic did the work and after, he told me that the control module is also leaking. Does this a big issue and does it affect the transmission preformance? Thanks alot and looking forward for your most appreciated reply.
May 7, 2010 at 8:58 AM
  • 75,988 POSTS
If the TCM ( Transmission Control module ) is actually leaking might end up shorting out-liquid is an electrical condutor it passes current
May 7, 2010 at 9:25 AM
