compressor not working
96,000 MILES • 6 CYL • 2WD • AUTOMATIC
BHJAGSFAN
All the sudden I cannot hear the compressor turn on...Aproximately how much should the repairs be. Also, let me say that the back part of the van had been blowing out warm air before this...I figured it just needed freon.
Aug 6, 2008 at 7:16 AM
JOELPB
If you are low on Freon, the compressor will not come on. You can short the pressure switch to see if it will then run, but if it is low just do this momentarily. You can recharge it with a kit or pay someone else to do it. If you have a leak, the cost will vary a lot depending on the problem. Find a good ac repair shot
Aug 6, 2008 at 1:13 PM
