2000 Dodge Caravan Codes from test
2000 DODGE CARAVAN
RUSS N WENDY
Transmission problem
2000 Dodge Caravan Front Wheel Drive Automatic 118,00 miles
My engine light came on a couple of days ago and when Russ went to have it tested at Checker the codes came back -
aa Transaxle control system fault
aaECM received a signal that the transaxle control aamodule has a fault
probable cause:
aa1 shorted or open circuit withing transaxle
aa2 failure of transaxle control module
They said maybe a wire had been chewed? We did have a desert rat's next in the car a few months ago, but didn't notice anything then. Russ changes out a lot of parts in the cars, has never done anything with that. How hard of a repair is this?
Nov 25, 2009 at 8:33 AM
CH112063
  • 1,320 POSTS
The ECM codes know about any codes stored in the Transmission Control Module. A shorted wire usually blows a fuse in the power center, have him check these first, under the hood, All the wiring for the transmission is pretty easy to follow and check. Good luck. A scan of just the TCM can help locate the exact wires to check. ok I don't know why any animal would eat a wire, it shows how desperately hungary these rats can get. I usually only eat Rolls wires. lol
So remember to try to get this scan. There are too many trouble codes, and too many wires and rats, terrible.
Nov 25, 2009 at 12:22 PM
