2000 Dodge Caravan checkenginelighton
98,000 MILES • 6 CYL • FWD • AUTOMATIC
GREGBENGAL
van had a hiccup then ceckengine light came on and is running hot and doesnt seem to be shifting
Mar 8, 2009 at 11:12 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:957a91c3d0="gregbengal"]Engine Mechanical problem
2000 Dodge Caravan 6 cyl Front Wheel Drive Automatic 98000 miles
van had a hiccup then ceckengine light came on and is running hot and doesnt seem to be shifting[/quote:957a91c3d0]
With the engine light being on you will need to have codes pulled. If you can take it buy your local auto parts store and have them pull codes and post them here.
It sounds like your tranny is in Limp Mode. And that could either be a sensor, the Transmission Control Module or and internal problem.
The over heating could be that the fans are not coming on to cool engine, a bad radiator, or a bad thermostat.
It could also be a few other things, so if possible get the codes read for better diagostic.
Mar 8, 2009 at 11:30 AM
