2000 Dodge Caravan changed radiator fan
190,000 MILES • 6 CYL • 2WD • AUTOMATIC
MIKEFINNEGAN
Hello, I changed out my radiator fan assy. The right fan motor was burned out and it burnt the 40 amp fuse that ran the fans. I changed out the assy. and reset the check engine light that was on due to the fans not running. the check light won't come back on but I have not seen the fans running yet. I let the van idle until the temp guage got to haflway and the fans didn't start once. Is there still some thing wrong? Thanks
Jul 25, 2010 at 1:41 PM
  • 110,248 POSTS
They won't turn on at the half way point. Has the vehicle ever gotten hotter than that?
Jul 26, 2010 at 5:24 PM
MIKEFINNEGAN
Not very often does it get past halfway. How hot does it need to get to turn them on?
Jul 27, 2010 at 2:08 AM
  • 110,248 POSTS
The factory thermostat doesn't fully open until 195 degrees F. The fans will usually come on around 215 to 220 degrees.
Jul 27, 2010 at 4:14 PM
JAYDEE427
Let the engine run until it reaches its normal operating temperature range (which is normally the half-way mark) and then turn on your ac (air conditioner) on all the way / MAX. Wait a moment (2 - 4 minutes) and and see if the fans come on then. That procedure activates the aux. fan in order to assist in the cooling process.
Also double-check and make sure you plugged the fan harness back in....lol.
Jul 29, 2010 at 8:14 AM
