2000 Dodge Caravan anti-theft..alarm system
94,000 MILES • 6 CYL • FWD • AUTOMATIC
DN_MARTZ
  • 12 POSTS
alarm went off lights and horn blew..couldnt get it to shut off so I disconnected the battery ground. Now none of the three things will work. What could be the problem...thanks? Checked all fuses..good..
thanks
Don
Apr 22, 2010 at 4:51 AM
BMRFIXIT
  • 19,053 POSTS
Need to check for codes B codes have to have a scanner to do so
You can try and disconnect BCM for few min and then reconnect
Body Control Module located on junction block, behind left side of dash.
Feb 7, 2019 at 2:52 AM
