2000 Dodge Caravan
MICHAEL VANISON SR.
  • 2000 DODGE CARAVAN
  • 6 CYL
  • 96,000 MILES
Tramission bump when it gets above 50 miles per hour and when I first take off.
Friday, October 24th, 2008 AT 9:30 AM
  • 109,896 POSTS
Hi:
Check for a broken transmission or motor mount.
Easy way to check the motor mounts:
With the car running, the e-brake on, your foot firmly on the brakes, and nothing in front or behind you, place the van in drive and gently push on the gas so it loads the engine /driveline. Watch the engine while you do this. Do the same in reverse. If the engine lifts or moves excessively, you most likely have a broken engine mount.
Let me know if you have any questions.
Monday, October 27th, 2008 AT 11:22 PM
