1999 gr caravan 3.3L - codes without scanner?
NOSHADETREE
I need to get the trouble codes, but I don't have a scanner. Is it possible to retrieve the codes by using the key in the ignition? I used to have a 1996, and was able to do it with that one. Could it be that I had OBD-I on the 1996 and I have OBD-II on the 1999?
Jul 16, 2007 at 5:30 PM
BPRICE443
  • 66 POSTS
It is possable but unlikely most all vehicles where obd 2 complyant in 1996. They might have stopped code retreaving by key process so that the average person can't work on it anymore.
Jul 25, 2007 at 4:59 PM
NOSHADETREE
I bought a scanner, one of the cheap ones of course. I was able to confirm misfiring in one of the cylinders. Anyway, the interesting part, the guy at the parts store had a puzzled look when I explained that doing the key trick was not revealing any codes. He was sure that even with OBD-II, the key process should still work. Furthermore, since it has not worked, I may have a problem with the chips (PCM, ECM, etc.) Anyone have a conflicting opinion on this one? It makes sense to me.
--Finally got time to dig into this one. It turned out that one of the spark plugs barely had a "nubbin" of an electrode left. It was in the number 1 cylinder, but my codes were showing misfires in number 3. Any explanation? Changed the plugs and wires, runs great now!
Jul 29, 2007 at 5:27 PM
