1999 Dodge Caravan windshield washer problems
BRADMACISAAC
Engine Mechanical problem
1999 Dodge Caravan 6 cyl Front Wheel Drive Automatic 245k miles
My rig is old and on it's last legs have 6 months more of payments so trying to diagnose problem on my own.
when I squirt the windshield washer it looks like it needs help only coming out in spurts.
Would this be a pump problem or just a fuse.
(when I push the button in it only shoots just barely to the bottom of the windshield and I have to continually push the button).
Thanks for any help
Cheers Brad M
Jan 14, 2009 at 10:01 AM
POLISHMAFIABOSS
  • 27 POSTS
It wouldn't be a fuse or it wouldn't squirt at all. I would look for a kink or bend in the hose going from the washer fluid resevoir to the wipers first. Second, take a small sewing needle or straight pin and clean out the holes the fluid comes out of the squirters. These can sometimes get clogged over time. The last thing I'd think it could be is something clogging the outlet in the resevoir where the pump is located. Look into the tank and see if there's some gunk in the bottom.
Jan 14, 2009 at 11:03 PM
