1999 Dodge Caravan wierd noise
136,000 MILES • 6 CYL • FWD • AUTOMATIC
SASSYEMT
Whie i was driving down the road i heard a screaching coming fom under the hood thought it could be a belt from the sound of it. Had regular power and it drove fine. the next day it got worse. It didnt make the noise when i started the van only when i got above 15 mph. upon further inspection i realize it is coming from the transmission it shifts but is now cant get out of its own way. what could the problem be????
Mar 26, 2010 at 11:19 AM
  • 110,248 POSTS
Are you sure it is the trans? Is it slipping? Is there anything that changes the sound / pitch such as turns, braking...?
Mar 29, 2010 at 5:06 AM
SASSYEMT
no the sound doesnt change only happens when in gear when driving over 15mph and just found out it will do it in Neutral when i hit the gas. at frist it drove fine then the next day while on the highway i was trying to pass someone who stopped suddenly i noticed it didnt want to move fast enough, then it was slowly losing power to want to go.
Apr 1, 2010 at 11:55 AM
  • 110,248 POSTS
Does the engine rev but not accellerate? Has the check engine light come on?
Apr 1, 2010 at 3:58 PM
