Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Caravan
Engine
Oil Pump
1999 Dodge Caravan where is oil pump located
1999 DODGE CARAVAN
130,000 MILES • 6 CYL • FWD • AUTOMATIC
ROB24680
MEMBER
1 POST
what could make the oil pressure light to come on and where is the oil pump located on the 1999 dodge caravan.
Mar 20, 2008 at 8:52 AM
BMRFIXIT
Experienced Mechanic
engine size will help here ?!?! you have to remove oil pan and front timing cover belt or chain out crank pulley and seal out
Mar 20, 2008 at 1:43 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
