1999 Dodge Caravan van died while driving will not start ag
TOMTOMTOM
  • 1999 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 12,400 MILES
Van was running fine, just stopped running while driving, had it towed home, engine turns over fuel pump is working, but there is no spark, what needs to be changed. Thanks tom
Friday, February 19th, 2010 AT 9:33 AM
JDL
  • 16,098 POSTS
Hi, what is litre size of engine? I looked at info for 3.0L. I always look for rpm signal. Did you check primary voltage at the coil, engine cranking, dark green wire with orange tracer. If no voltage, that leads back to the asd relay. The computer won't energized asd relay, other than initial prime, without proper cam and crank signals.
Friday, February 19th, 2010 AT 10:04 AM
