1999 Dodge Caravan transmission noise
DJS1958
Transmission problem
1999 Dodge Caravan Front Wheel Drive Automatic
I have a Dodge Caravan with 3.3 engine, The problem that I have is that when you put it into ANY forward drive gear the only thing you get is a growling noise (simular to a strip gear sound). There are no problems with the transmission in reverse. Just a guess could it be that the control module is bad, or some type of forward gear selector is bad
Thanks '
Dave
Sep 19, 2010 at 6:49 AM
BILLYMAC
  • 2,204 POSTS
it could be a broken snapring inside the trans or even a differential failure
Sep 24, 2010 at 1:07 PM
