1999 Dodge Caravan Transmission Connected to a Fuel Pump?
1999 DODGE CARAVAN
200,000 MILES • 6 CYL • FWD • AUTOMATIC
WFREDCROW
I had the engine and transmission replaced 3 months ago. Refurbished equipment. Recently on the freeway, driving was fine until we slowed for traffic. Then the transmission would not shift - to safely get off freeway RPMs were 4500 at 50mph. I drove home using surface streets. By then the transmission was shifting okay again. I turned van over to mechanic for evaluation. They reported the shifting was fine but was connected to low pressure in the fuel pump. Huh? Thnis cost $650 to replace. When I picked it up, a second mechanic said the two were not related. Was I ripped off? Being non mechanical feel like a fool.
Oct 7, 2010 at 6:07 AM
F4I_GUY
  • 3,302 POSTS
Thank you for your previous donation.
Your fuel pump and transmission shifting are NOT related. If you have a faulty fuel pump in your vehicle, your vehicle will either not start, or it will run rough or have a hesitation.
The transmission not shifting has to do with an internal valve in the transmission.
Oct 7, 2010 at 8:01 AM
