1999 Dodge Caravan Ticking, engine light on, then off, then
MOMMASTAXIRUN
  • 1999 DODGE CARAVAN
  • 6 CYL
  • 130,000 MILES
Hello, we left our beloved van to sit for a week at the airport with no known problems. When we picked it up there was a noticeably loud ticking from the engine. We found that the oil was very low, and refilled it. A few days later, the "Service Engine Soon" light came on, and the ticking was more pronounced with acceleration; almost nonexistent when idle. The next day, no more ticking and the light went off. Great, right? That night (last night), pulling into our long drive, I was unable to move forward without pressing hard on the gas, and felt resistance (NO, my e-brake was not engaged!). The car wouldn't move in drive - almost like the brakes were engaged. This morning we drove about 35 miles with no problems, no resistance, no ticking, no lights. After parking about an hour, I restarted engine and sat idling to run a/c for about 1/2 an hour. When I tried to back out of my spot, the car was resisting again. I checked the brakes, pumped them, etc. I also moved gear shift from gear to gear. When I drove out, the resistance became stronger the further I drove. About a 1/2 mile out, I could barely move. The only way I can describe it is a feeling of tension - pressing so hard on the gas and revving but not moving much - and if I pressed too hard it would snap. Needless to say, we towed it out. ANY suggestions are SO appreciated. Thanks! I promise to donate next time - I am so broke today.
Friday, May 8th, 2009 AT 8:01 PM
  • 109,758 POSTS
You need to have the computer scanned for codes. If the check engine light was on, there will be a code identifying what the problem is. Most parts stores will do it for free, so there is no money out of pocket.
Let me know what you find.
Tuesday, May 12th, 2009 AT 9:59 PM
