1999 Dodge Caravan sticking caliper
110,000 MILES • 6 CYL • FWD • AUTOMATIC
DONPON
We have replaced the passenger side front brake caliper 3 times in the past 5 months. It keeps sticking, and when you change it the rotars are very hot and needed replacing. Tried different brands of remanned calipers so the part is not the problem.
Nov 17, 2008 at 5:20 AM
ZACKMAN
  • 4,202 POSTS
Did you bleed the brake system after replacing the caliper? Did you re-grease the slider bolts before you put them back in? Did you tighten the bolts to the torque spec?
Nov 17, 2008 at 1:46 PM
