1999 Dodge Caravan starting the van
94,000 MILES • 6 CYL • 2WD • AUTOMATIC
ANITA1954
i have had my van tested for the starter battery and alternator they were fine the only way i can get it started is to play with a green wire connected to the fuse relay distribution box. what could be wrong and how do i fix it
Aug 8, 2010 at 5:21 AM
  • 110,248 POSTS
There are a lot of wires there. Have you checked to see where that wire goes? Also, when it doesn't start, is it completely dead or does the starter work?
Aug 8, 2010 at 3:55 PM
ANITA1954
yes it will start. there are two wires there one red that goes to the positive cable and one green one im not sure where it goes it is all harnessed,the starter battery and alternator all checked out ok
Aug 9, 2010 at 2:32 AM
  • 110,248 POSTS
I looked at some schematics. If it is dark green with a red tracer, it runs to the ignition switch, dark green with white tracer, fuel pump relay... There are a bunch of other green wires with different color tracer colors. Check to see if it is solid green (which I can't find) and if it has a tracer color, what color is the tracer.
Aug 9, 2010 at 5:34 PM
