1999 Dodge Caravan starting
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
TBRAUE
I turn the key and nothing. I repeat this 2-3 times and it kicks over and seems fine. Is my starter going?
Jan 15, 2008 at 12:37 AM
MERLIN2021
  • 17,250 POSTS
When you say it has trouble what kind? Clicking? or nothing at all? If you hear a click, then either the battery is weak, or the starter, possibly bad battery cable connections, check and clean both ends of BOTH cables! Dissconnect negative(-) first, and put it on last! If no click the starter relay is no good!
Jan 15, 2008 at 12:48 AM
