Disconnect battery negative cable
raise vehicle
remove wires at the rear of the starter
remove 3 bolts holding starter
remove starter
Mar 21, 2008 at 3:07 PM
ROADVULTURE9986
MEMBER
How do I replace the starter on this vehicle?
Jan 6, 2020 at 3:49 AM
(Merged)
JDL
✓Experienced Mechanic
Welcome to the forum, take the negative battery cable loose. The pictures below, came from autozone.
(Merged)
MICAHNETT
MEMBER
how do i replace starter in 3.0, 6 cylinder '95 caravan?
Jan 6, 2020 at 3:50 AM
(Merged)
SATURNTECH9
Here you go.
1. Disconnect battery ground cable, then raise and support vehicle.
2. Remove starter motor attaching bolts and nuts.
3. Disconnect all electrical connectors from starter motor and remove starter.
4. Reverse procedure to install.
(Merged)
MICAHNETT
MEMBER
i think the 3 bolts are 13mm...electrical part 1/2in and (8mm) something small
(Merged)
SATURNTECH9
I don't know the bolt and nut head size's but they should all be metric size's.
(Merged)
MICAHNETT
MEMBER
thank you for your help
(Merged)
MAVP618
MEMBER
1 POST
how to replace a starter in a 1995 Dodge Caravan
(Merged)
SATURNTECH9
your welcome that's what were here for.
(Merged)
CARADIODOC
Disconnect the battery negative cable. Disconnect the two wires from the starter. Remove the bolts that hold the starter to the transmission. Remove the starter. Reverse the procedure with the new starter.
(Merged)
PHILOSOPHER11
MEMBER
1 POST
How do I replace the Starter on a 1994 Dodge Caravan?
(Merged)
Hi:
Disconect the battery first. Next locate the starter on the front of the engine at oil pan level. Now disconnect the wiring to the starter. Make a mental note of wire location. Now, there are two bolts holding the starter on to the trans. Remove the bolts and the starter will come off. Replace it in the reverse order.
(Merged)
RICKADAMS
MEMBER
1 POST
How do you change a starter in a 1993 Dodge Grand Caravan? I have read many online answers and some say I need to remove the tire to get access, while others say I need to remove the exhaust manifold, while others just say remove the three bolts with no suggestions on where they are located.
(Merged)
HMAC300
disconnect negative battery terminal end then remove starter wires and 3 bolts holding it in. Here is a guide that will walk you through the steps to show you how its done on your car.
