1999 Dodge Caravan speedometer/fuel gauges
SERGIO26
Electrical problem
1999 Dodge Caravan 6 cyl Two Wheel Drive Automatic 100.00 miles
hi is possible can help me how to fix my speedometer/fuel gauges is not working
Apr 11, 2010 at 4:46 PM
CH112063
  • 1,320 POSTS
Are any of the others out? the fuel gauge is controlled by the sending unit on the fuel pump, in the gas tank. The speedo may be bad itself. You can find out exactly why they failed bt using a scanner. It stores codes and operated these. Do you know how to use a test light and a voltmeter? If you do get the fault codes and let me know exactly what they are. On some engines the vehicle speed sensor controls the speedometer information.
Apr 13, 2010 at 1:13 PM
