1999 Dodge Caravan rear brake drums
DARKCHOC
Brakes problem
1999 Dodge Caravan 6 cyl Two Wheel Drive Automatic
can not remove rear brake drums. Is there a way to relieve the pressure on the shoes?
Feb 14, 2009 at 3:33 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Yes, if the drum is difficult to remove, remove the plug from the rear brake support plate. Push the self adjuster lever away from the star wheel using a thin screwdriver. The lever and star wheel are accessed through the hole on the rear brake support plate. Rotate the star wheel using a brake adjusting tool to retract the shoes.
Thanks for using 2CarPros.com!
Feb 14, 2009 at 4:30 PM
