1999 Dodge Caravan Problems starting
150,000 MILES • 6 CYL • FWD • AUTOMATIC
AKVAN
This van refuses to start. We replaced the starter, we thought that was the problem. The dash lights up, the heater kicks on and the relay makes clicking noises. The fuses are fine as is the battery. The oil is full. We have an autostart on the vehicle. It is turned off and it still refuses to start. Any help would be appreciated.
Jan 4, 2009 at 9:47 PM
BMRFIXIT
  • 19,053 POSTS
Have to check for power at the starter small wire when key is in the start position
also check fuses when key is in the start position using a test light
disconnect BCM and reconnect
check ignition switch
check neutral safety switch
check wiring
Jan 4, 2009 at 10:20 PM
AKVAN
Where is the BCM located? I had to look it up to find out what is was but still don't know how to find it.
Thanks
Jan 6, 2009 at 5:54 AM
BMRFIXIT
  • 19,053 POSTS
BCM
body control module located on the junction block ,behind left side of dash
Jan 6, 2009 at 8:54 AM
