Have to check for power at the starter small wire when key is in the start position
also check fuses when key is in the start position using a test light
disconnect BCM and reconnect
check ignition switch
check neutral safety switch
check wiring
SPONSORED LINKS
Monday, January 5th, 2009 AT 6:20 AM
