1999 Dodge Caravan problem with engine running hot
ARRANNEN
  • 1999 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 210,000 MILES
Last winter was extremely cold, and on my way to work on one of the colder days, my check engine light came on.I heard a "thunk" from the engine, and after that the check engine light never came on again.
Now, this summer I've been noticing that my van has been running hot ( about in the middle of the temperature range) and the coolant return hose to the radiator when the car is turned on normally I could feel coolant moving through it and NOT be able to pinch the hose, now I can pinch it almost together and dont feel anything moving. Both my radiator and overflow are full of coolant. I'm wondering if this could be as simple as the thermostat not working correctly or if its the water pump. How would I go about checking to be sure which it is?
Friday, June 27th, 2008 AT 10:06 AM
DOCFIXIT
  • 18,828 POSTS
Doubt it is water pump sounds like a thermo. Not opening all the way. Try running with cap off see if flow is there.
Let me know
Friday, June 27th, 2008 AT 10:52 AM
ARRANNEN
Took the cap off, and no flow still. Didnt even look like the coolant was moving in the radiator.
Friday, June 27th, 2008 AT 11:13 AM
DOCFIXIT
  • 18,828 POSTS
Replace thermostat seems the next step. Also did you have codes checked afteyour thunk light on?
Friday, June 27th, 2008 AT 11:19 AM
ARRANNEN
Ok, replaced the thermostat this afternoon. We'll see after tonight what happens!
Friday, June 27th, 2008 AT 2:50 PM
DOCFIXIT
  • 18,828 POSTS
I'll keep my fingers crossed
Friday, June 27th, 2008 AT 3:06 PM
