1999 Dodge Caravan power steering leak
16,700 MILES • 6 CYL • 2WD • AUTOMATIC
RICKYCHEATHEM
what would cause the power steering to start leaking
Sep 8, 2009 at 3:30 PM
CARADIODOC
  • 34,413 POSTS
Can't really tell from here; I can't see that far. Is it leaving a puddle on the ground? A professional will look at the pump on the passenger side of the engine, the rack and pinion assembly on either side, and the hoses in between. Based on the mileage, I'd suspect the rack and pinion assembly first, but have a mechanic look at it. Power steering leaks are usually easy to pinpoint.
caradiodoc
Sep 10, 2009 at 7:42 PM
