1999 Dodge Caravan power steering leak
RICKYCHEATHEM
  • 1999 DODGE CARAVAN
  • 6 CYL
  • 16,700 MILES
What would cause the power steering to start leaking
Tuesday, September 8th, 2009 AT 10:30 PM
CARADIODOC
  • 34,396 POSTS
Can't really tell from here; I can't see that far. Is it leaving a puddle on the ground? A professional will look at the pump on the passenger side of the engine, the rack and pinion assembly on either side, and the hoses in between. Based on the mileage, I'd suspect the rack and pinion assembly first, but have a mechanic look at it. Power steering leaks are usually easy to pinpoint.
Caradiodoc
Friday, September 11th, 2009 AT 2:42 AM
