1999 Dodge Caravan Park lights
1999 DODGE CARAVAN
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
KAJUNN98
Grand Caravan w/fog lights, w/o daytime lights.
The driver side park lights (front & back) have stopped working and no signal is found at either light socket. Fuse checks good and I swapped the relay and nothing changed.............. Switch or wiring problem in your expert opinion?
Thank you
Feb 23, 2010 at 1:11 AM
KAJUNN98
Turns out that: the light switch feeds BOTH side parking lights on ONE wire, so if one side works it is not going to be a headlight switch failure: there are two fuse panels-one under the hood & one under the dash on/dr sd:The problem was a burnt fuse for the drivers side park lights that was located in the fuse box under the dash. I did swap out the relay first and that was not the problem and then sought help from a mechanics shop that was kind enough to print out the schematic for me so I could understand where the problem was likely to be.
Feb 25, 2010 at 7:28 AM
