1999 Dodge Caravan Oil pump gasket
TOMSHANTY
  • 34 POSTS
1999 Dodge Caravan 6 cyl Front Wheel Drive Automatic
Hey guys. I want to replace the gasket between the oil pump and the engine block. The Haynes book says that I need to remove the oil pan and pick-up tube. Is this absolutely necessary if I am just replacing the gasket? The engine is being supported with a floor jack under the oil pan because I had to remove the passenger side engine mount. Thanks.
P.S. I have found this web site helpful. Moneys tight right now, but I'll donate soon.
Aug 8, 2009 at 8:57 PM
BMRFIXIT
  • 19,053 POSTS
pick up tube connected to pump housing
Aug 8, 2009 at 11:14 PM
