1999 Dodge Caravan Nothing is working with cluster
RUSHINGF
  • 1999 DODGE CARAVAN
  • 6 CYL
  • 160,000 MILES
The lights work but none of the instrument clusters or air condition buttons is working. When I press on the recycle air button the speedometer and other cluster stuff would work now it does nto work at all. Any suggestioins?
Thursday, February 5th, 2009 AT 4:41 PM
  • 109,885 POSTS
I want you to try disconnecting the battery for about 10 minutes. See if that helps.
Thursday, February 5th, 2009 AT 7:21 PM
RUSHINGF
Disconnected battery still not working. The heater is sendiing hot air also.
Monday, February 9th, 2009 AT 11:07 PM
  • 109,885 POSTS
What I suggest is having the body control module (BCM) tested.
Tuesday, February 10th, 2009 AT 11:42 AM
RUSHINGF
Where is the BCM located?
Tuesday, February 10th, 2009 AT 4:16 PM
  • 109,885 POSTS
Hi:
I think on your vehicle it's on either the driver or passanger side kick panel.
Tuesday, February 10th, 2009 AT 4:19 PM
