I have run out of things to check. My 99 caravan was running fine one day. The very next day it was dead as a doornail. The only clue I have is that this happened during freezing overnight temperatures. Since then I have replaced the battery, checked the fuel pump (good), fuel pressure (good, checked with gauges), coil (good, checked voltmeter readings with repair manual), timing belt (good), and there were no engine codes when scanned. Probably because the battery had been disconnected for quite some time. I have taken off and cleaned the IAC valve, TPS sensor, MAP sensor, and checked to make sure they are operational. I even put the noid lights on the injector wires. I don't know what else to check short of having it towed to the dealer. Got gas, got spark, no crank. What makes this so confusing to me is that it did not run rough before it just went dead. Any ideas? Thanks in advance!
SPONSORED LINKS
Saturday, September 5th, 2009 AT 12:11 PM
