1999 Dodge Caravan Instument Cluster
MICHAEL110277
Electrical problem
1999 Dodge Caravan 6 cyl Front Wheel Drive Automatic
1999 Dodge Grand Caravan instument cluster will go out lights still work but guages all drop to 0. After finding that a good smack just above the cluster would bring it back to life, had to do this several times. After one time the speedometer stuck at 30mph as if it where at zero! (ie. 55mph is now reading 85mph on spedometer) is there a way to reset the spedometer needle to zero??? [img:7a8ebf5a73]http://www.2carpros.com/forum/automotive_pictures/532835_carrunninginpark_1.jpg[/img:7a8ebf5a73]
[img:7a8ebf5a73]http://www.2carpros.com/forum/automotive_pictures/532835_car_off_1.jpg[/img:7a8ebf5a73]
May 29, 2010 at 10:03 AM
BLUELIGHTNIN6
  • 16,542 POSTS
sounds like might be some faulty wiring behind cluster or the gauge cluster itself is needing replaced. the only way to reset the speedo is to calibrate the gauges. you must use a diagnostic scan tool to do this..
May 29, 2010 at 10:08 AM
