1999 Dodge Caravan Idle vibration felt through steering whe
125,000 MILES • 6 CYL • FWD • AUTOMATIC
OINGO
A vibration is felt through the steering wheel while sitting at idle. Idle speed appears normal at @ 750-750 rpm. Cleaning the Throttel Body doesn't change it. I don't drive it but noticed that after oil leak was fixed (front cover, had Water Pump replaced at same time) I will be checking egr but it engine seems to be running fine (not rough) but a shaking or vibration is occuring like something is out of balance.
Thanks
Dec 24, 2008 at 12:21 AM
ZACKMAN
  • 4,202 POSTS
If your idle speed doesn't change, then I would check your engine mounts.
Dec 24, 2008 at 2:42 PM
