First you need to check the vehicle speed sensor. It is located on the transmission (see diagram below).
This sends the signal of the vehicle speed to the ECM and having a faulty sensor the ECM will not received the required data, which can prevent the vehicle from shifting.
https://youtu.be/f3bETtCIdxM
Sep 2, 2021 at 5:01 AM
