speedometer quit and now it transmission will not change gears?
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
SHARON 42
i have a van th speedometer quit and now it wont change gears?
Dec 16, 2009 at 10:16 AM
SQM
  • 6,383 POSTS
First you need to check the vehicle speed sensor. It is located on the transmission (see diagram below).
This sends the signal of the vehicle speed to the ECM and having a faulty sensor the ECM will not received the required data, which can prevent the vehicle from shifting.
https://youtu.be/f3bETtCIdxM
Sep 2, 2021 at 5:01 AM
